The steering is active, so it’s uses input from the speed sensor. If the speedometer fails to work it will stop the power assist steering. You car being an import will likely have a speed converter behind the dash, loose connection here on this circuit will be the cause. You tapping probably remade the connection. Also the speed sensor on the gearbox can pop out the end, be loose, simply slowly down and speeding back up it can kick back to life.
By
Stephen ·
Hi guys, just wondering if the two red zeds i see today, have seen both on several occasions, were any of you?
One is a G plate with standard wheels (painted gold) usually on plough road, Great Bentley
The other is a H reg with full bodykit etc on Old School Lane, Elmstead. Doesn't look like its moved in a while though.
