Hi Guys
seen lots of examples of engine bays cleared of fuseboxes and other stuff what can be relocated and where is the best place to resite it
cheers
it can all go other places.
ย
Mine here. PS pump up by small fuse box. No HICAS as NA subframe. Clutch bleed deleted for one SS pipe. large fuse box down where air con pump was. all done with engine in. Engine is now out so i plan on moving 90% of the engine bay
ย
did you think about relocating main fuse box to inside maybe glove box?
ย
Nope i use that for other stuff and would be mental to extend that many wires. It has been moved under the headlight panel before and down by the left IC when using a FMIC but you need to start extending wires.
ย
As for lights well the looms tuck away nicely when you have HIDs.
ย
This was attempt one anyway as the car is now stripped and everything will be moved to hide away all the wires
Have you ever relocated your smaller fuse box to the wheel arch? Is there any issue with water behind the arch liners?
the only drama woukld be if you needed to change a fuse would be a pain. However i will look at putting it somewhere else. I cant see an issue of it getting wet there though
