- Replies 27
- Views 854
- Created
- Last Reply
111mattin111 13 posts
groover 3 posts
300_zedx 2 posts
MarkDerby 2 posts
Ok so I'm in the process of fitting the new belt, on the belts they have yellow lines on so you know the dot on the camshaft wheel lines up with the dot on the back plate for some reason my line is always a tooth out even though the dots line up as I'll show in a pic
As you can see here the yellow line on the left cam wheel lines up but the one on the right is a tooth out but you can see the two white dots line up
And again here
Also can't seem to get the belt on the auto tensioner as its to tight for some reason
Please help as its now really winding me up
