speedo pin out diagram
be aware that there are differences between the Series 1 and 2... (on the S2 the two plugs together on the left are horizontal and the wiring is slightly different, I think)
http://stadzport.com/FSM/EL_Electrical.pdf
page EL-41
Nice link, ill add that to my favs. I think Rolandas' is a series 1. Just use it as a guide and confirm each wire with a meter before you splice into the looms. The fuel level gauge (according to the manufacturer) will be within the operating range of the oem sender unit, but I would be cautious of your fuel levels until you can prove it lol! The fuel gauge reads from 1-99 as a % of full.
Everything should be pretty straight forward but there's a fair amount of splicing, can't wait to see them done, wish I had the time myself, I know I'll regret selling when I see them up and running! Good luck...
to connect everything is easy :) i just would like to know pin out of the actual speedo of them 4 screws that connects to pcb. But i will figure it out :)
So, How do I stop my car bleeping when its in reverse, and how do I stop it beeping everytime I go over 110kmph. ?
The reverse beep unit, is under the dash, above where the top of the clutch pedal would be... you can eliminate the beep y taking the box apart, but deleting the box altogether, you will need to find the wires to connect for reverse lights.
You can take the light/speed chime box out altogether with no adverse affect, apart from no bonging when the lights are left on and door open, thats behind the dash cowl to the left behind the clocks.
