TT conversion to a NA diff
can somebody tell me exactly what would be involved in the conversion , the pitfalls and of course exactly what i will need , thanks
sayers
Bolt on bolt off isn't it?
You need the whole thing from the Na, prop too im guessing.
yep, whole back end. subframe and everything that is directly bolted to it and the rear half of the prop.
can i use my existing half shafts ??? and simply recconect them at the diff end
what about suspension, wheel hubs and brakes , are these all different as well ????
is it possible to swap the internals of the differential
no ... the only things you will reuse is Brakes/calipers/handbrake pads and mech & Shocks
you will be swapping
Subframe
Wishbones/arms
hubs
Diff
Half shafts
center Propshaft
Okay then, does anybody have a NA they are breaking that i can take the parts from ???
