ICE
I installed an active sub over the weekend so had to run a live from the battery, through the inner Emperor Ming above the ECU etc. through to the ar$e end.
Right so now I may need to install an amp for the rear speakers I plan to put in at some point.
Q. Am I correct in thinking that now that I have a live feed from the battery that is it? That now I just distribute other live feeds that I may need from that cable?
"I love to go down to the schoolyard and watch all the
little children jump up and down and run around yelling
and screaming. They don't know I'm only using blanks."
Emo Philips
[This message has been edited by Timmy_Turbo (edited 28-08-2002).]
Basically Yes, but what gauge wire did you use? if your're gonna have your big system then I wrecken 4 gauge is a must!!
Vijay
Vijay's right, one live feed (and an equally good local earthing point (plenty of options on the boot floor) is all you need.
Only proviso is the current that you can safely draw through the cable without making it hot and causing your zed to go up in smoke. frown.gif
I've got 8AWG running a 2x95w RMS amp in the back and it's cold as ice. If you wanna be really safe or are thinking of running or upgrading to a monster system , run 4AWG cable.
Don't forget that your earth cable needs to be same rating and install an inline fuse in the +ve wire as close to the battery as you can to keep things safe.
Jim
yep Jim's made a good point - don't forget the inline fuse as near to the battery as possible!! I didn't in my 200sx and shit myself when I earthed the power wire by accident.........
Viajy
Thanks guys!
I used an Autoleads Amp install kit from Maplin and it doesn't say anywhere about the core thickness. This should be OK shouldn't it?
Amp will more than likely only be running the front and rear speakers as the sub drives itself.
It comes already fused just off the battery terminal so no worries there.
Emo Philips
Timmy, if you look at the writing on the wire, it will have the guage written on the side wink.gif
CheerZ,
Andy
Cheers Andy I did ask Mrs T to check the cable but she couldn't see owt so I rang Autoleads up. 10AWG Max 420 Normans (Watts for those of you wondering "WTF is he on about?" LOL) so not overly thick! Gulp!
Probably literally just enough to power one amp and no more?
Bummer!
Emo Philips
just measured my cable and it's about 10mm thick (including sheathing). It might be worth you re-doing if the interior bitz are still out and then use that 10 gauge stuff that you have to run to the amps from the distributor/fuse block.
Vijay
Oh man not again!
It won't be such a bitch of a job now I know where the cable enters the bulkhead on the inner wing I suppose.
I'll head off to Maplin tomorrow to buy some decent stuff and then rewire at the weekend.
Existing cable isn't running through the Wallace & Gromet properly anyway so I would have had to pull it anyway.
Cheers for all your help and nifty replies chaps, much appreciated as ever. wink.gif
Emo Philips
BIG THANKYOU!!!
...goes out to me old Z bend(Friend) Vijay!!!!!!!
Who has just enlightened me on how to get a 4 gauge cable inside the car in 5 minutes as opposed to about 2-3 hours of swearing, sweat and threats of fcuking suicide! ;-)
Where would any of us be without this forum? I don't know at all! LMFAO biggrin.gif biggrin.gif
"New York's such a wonderful city. Although I was at the library today.
The guys are very rude. I said, "I'd like a card." He says, "You have to
prove you're a citizen of New York." So I stabbed him."
Emo Philips
Hey up there Timskoid!
you getting all ICE'd up then bud? - good man, its a p*sser getting that wire thru, I went in thru the passenger kick panel and up thru the wing - you can get quite adept at it after ten attempts smile.gif
Dont forget mate, passenger inner door for Trackers mate wink.gif that'll do it everytime!
Peace,
->Glen
Skyline GT-R
'You dont so much drive this car -
as hang on for dear life..'
J.Clarkson
hello timski my old fruit bat!!
sorry i didnt go to harlech that day hangover got the best of me!!!
with the ice install bud!! when u run the power lead through the car keep it all 2 one side!!
what i did was run the power from bat along the drivers side 2 the rear!! now run your output leads from your head unit to the amp on the opposite side of the car stops the annoying interfierence when u rev your z!!
try and keep the power leads away from the input leads and speaker cable at all times!!!
be a good idea to run your power remote cable from your head unit along with your batt lead on the same side of car!!
hope this is help 2 ya bud!! next time i c ya i'll show u how i wired mine up bud
c ya!!
Ding Ding...round 2...
Right just bought far too much 4 gauge and far too much 8 gauge wire and a two fused 24 carat distribution box from Joe Maplins.
I take it I'll be needing 8 gauge equiv. earth wires aswell?
Right boys and girls my next annoying ICE question...
Q1. What size fuse do I need to put at the battery?
Saw 5G holders which you can screw onto the bulkhead and look cool. But what size amp fuse 20amp, 40amp or 60amp.
Q2. Will be having 4 gauge going into the dist. block and 8 gauge coming out the other side. What size 5G fuses should I have in the distribution block?
TIA MARIA etc. etc.
Emo Philips
Depends on the fused rating of whatever you're running from it - if an amp, it should either tell you in the documentation with the amp, or just add up the total of the fuses on the amp.
Find out what power your amp(s) are ie. 300Watt, and P=VI (from A level physics), thus I (current)= 300/12 (12Volt battery).
Man i love physics! Im also excited bout goin to look at a Z at the weekend!
