Hicas delete using n/a powersteering pump.......which pulley?.
Would I be correct in thinking I would use a tt pulley on a n/a pump........or is there no difference between the pulleys?.
I used the NA pump and pulley and used a tt belt but cut one rib off to fit onto the 3 rib NA pulley than i was told you can use the tt pulley but fit it backwards onto the NA pump to give you the correct alignment and that way you can use the tt 4 rib belt .HTH
