Idle hunting
Ok since engine rebuild my idle isnt nice ...
you can rev it but then its up and down with in 100/150rpm
will tell you what i have tested and replaced
Tested 3 Maf's with and with out silien kit
Replaced Idle Control valve
no vac leaks tested up to 25psi
changed spark plugs for warmer ones
all connections are spot on
Timing Belt is spot on
15btdc pin 44 shorted
TPS 0.44
Base Idle done
Complete EGR Delete
just not sure ?
Edited by MarkDerby
  • Replies 39
  • Views 890
have you tried resetting the ECU? or checking for codes?
Check the tps voltage (0.44v) and that the connections good. If you need to set the tps then pull the plug on it for 10secs while engines running then plug back in.
Have you deleted the EGR Mark?-If not check the valve isn't stuck. You can also try disconnecting the O2 sensors see if the idle changes.
If you take off the iac connector can you adjust the idle with the screw?
TPS is 0.44
Done Base Idle
Compete EGR Delete
the only thing i haven't tried is O2 sensors
its possible for one to of packed up seems that the old engine dumped 3>4lt oil though the exhaust/intake system
Edited by MarkDerby
We put a pair of new O2,s on mine years ago and it hunted on tickover , i just disconnected them and all was well :confused1:
lol ok will try it tonite ...
if they need disconnecting I'm not bothered as the Tuning
will be to aggressive for them to work correctly anyways
Have you checked your vacuum caps are in place?(there may be a few if you have deleted stuff).......i lost a blanking cap off the balance bar and that caused a hunting idle, fitted a new cap and all was well again.
Edit.....just noticed you checked for leaks.......what plugs you got in it?, as I had a lumpy idle issue with ngk iridiums in and was advised by Jeff and a few other people to change them for standard plugs and that sorted it out straight away.
Edited by Rebel Scum
It could be that it needs running on the road for a bit and once the engine has bedded in a bit and the ecu has relearnt its settings it may settle down.....just a thought :)
its done 350 miles all ready the ECU only takes about 50odd miles to do its relearning
its quite confuzing as i have checked everything and swopped a few things over to test
i have another ECU chip and going to try unplugging O'2 sensors
Dont forget though that the engine will be tight (new bearings, pistons etc etc) plus if you have fitted uprated turbos and altered the fuelling with bigger injectors and ecu chip (cant remember what youve done to it) it may be that a lumpy idle is the trade-off for higher performance higher up the rev range.i know from experience that a lot of tuned engines suffer from a fluctuating idle which can be very hard or near impossible to cure.if it fluctuates by 100 to 150 rpm then theres something up with mine as it does that too when its warm but then again my v6 calibra would fluctuate by that much when that was warmed up as well.
yeah i get what u mean ...
will take a look at a few things later
taking it to Jeff on wednesday to put it on consult
check it over with timing & electric timing
the turbos was on the car before engine went pop
but didnt have idle problem
but like u say
Diffrent
engine
injectors
MAP
Did you adjust the idle air valve on a diagnostic? datascan ? adjusting the screw alone with no visible reading will be hit and miss. You are looking at an idle air reading of 15% again with the plug off the top of the valve while adjusting, then plug back in for the ECU to take over the tickover.
nope .. as my software is limited ... disconected plug set idle to around 800rpm then pluged it back in
I ran mine for years in standard form with no O2,s at all , never had any issues !! wierd
Base idle for a manual tt is 650 rpm with the yellow block connector removed from the idle valve.once its set at 650 rpm plug the connector back in with the engine still running and revs will automatically pick up to around 750 rpm as the ecu takes ov er control of the idle speed :)
ok disconected my o2 sensors and redid my base idle and still all the same
going to check my timing belt timing would find it hard to get it wrong as
it was all aligning up with the markers on belt and with markings on the engine its self
Maybe worth checking your ignition timing also.
Sounds like it maybe borderline and the ecu is tyring to over compensate.
ok been and checked my timing again this morning and all is Spot on ...
heres the pics
