June 21, 201214 yr So since i got the 300 about 2months ago ive slowly been rebuilding it as and when i get time. So this is what has been done so far, i started with the under side of the car, started to strip the suspension off ready to strip the old underseal off Once the old underseal was off i rubbed it back and gave it a coat of zinc primer, then a coat of underseal I then dropped the subframe off and took the worn out old bushes out, then sent the subby off to be shot blasted and powder coated, dont post yet more to follow lol
June 21, 201214 yr Author While that was being done i started to renew the brake pipes and fuel lines
June 21, 201214 yr Author Then got the subframe back and fitted the new driftworks solid bushes Then got this fitted Next up is to zinc primer and underseal the rest of the underside and spray the engine bay, and also lots of other things so check back for some updates as and when i get round to them
