August 25, 200224 yr I am looking to replace the water hoses on my Z, I am looking a Samco Hoses, but they only seem to sell 2 of them in the kit. Is this all that is required??
August 25, 200224 yr I have had all my water hoses replaced recently, and they consisted of: 2 radiator hoses #84.90 2 outer bukhead heater hoses #18.40 4 bypass water hoses #16.20 2 front engine water hoses #8.20 water coolant turbo pipe assembly #42.90 prices excl of VAT think thats all. cheers Steve
August 26, 200224 yr There's a mass of small hoses under the upper intake plenum. You can buy these as a kit from courtesy nissan. Here's the link:- http://www.courtesyparts.com/z32/oe_tt-1_water-hose.html The only other hoses worth bothering with are the heater matrix hoses that go from the engine to the bulkhead and the small rubber hoses between the heads and the top metal coolant hose at the front of the engine. The main top and bottom hoses - They are the ones samco do. There are also some bottom hose replacements out there which are stainless steel to stop the pipe collapsing due to its length - they aint cheap but could be worth it... HTH CheerZ, Andy
