Me again.
So I have two questions:
RobHowl ·
On the way with changing my turbo's and was just wondering if anyone knew what transmission oil to use? As I might as well change it while I'm at it.
Is 75W-90 Semi Synthetic alright?
Thanks in advance :laugh:
