Spark plug wrench
What size do I need? Just been in halfrauds and and a 10mm fit but was £15. Then when I was looking at some of the sockets the 10 was too small
Membership No 0780
INSURANCE GOOFA
The tools in Haslfords are not bad value, especially the pro range..
I have a trade card you can use mate...
Cool. I'll see if anyone at home has one first though. It was only the expensive one that fit (fooking typical) and it didn't fit my current socket set meaning I'd need to buy the top bits too
Membership No 0780
INSURANCE GOOFA
Dont buy the long socket, it doesnt have the angle and you can end up snapping the head off a plug.
Standard size spark plug socket will be fine, 10mm, dont confuse with a 10mm normal socket lol. The plenum gets in the way with the long reach socket.
When I was measuring the plugs up against them they didnt fit over the back of the spark plug properly
Membership No 0780
INSURANCE GOOFA
There is a rubber grommet inside the spark plug socket, which grips the plug to pull it out. You need to give it a bit of a push to fit.
