OBD II Scanner - Recommendation?
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi,
I'm trying to diagnosing an ABS fault on my Galant. I spend all day yesterday removing a sensor from a replacement hub that I bought (which had different size lugs for the calliper and didn't fit).
The ABS light remains on. I've replaced a ring and that sensor and I've checked all of the obvious.
Instead of paying Mitsibushi probably around £60, I figured I'd buy a reader, as its an OBD II system, and do it myself, plus its cheaper and I'm running out of money.
I'm looking at this -
http://www.ebay.co.uk/itm/Any-Car-Engine-Fault-Diagnostic-Scanner-Code-Reader-OBD-OBD2-OBDII-CAN-BUS-D900-/140625950490?pt=UK_Diagnostic_Tools_Equipment&hash=item20bdf5b71a#ht_12755wt_952
Will this allow me to read ABS codes?
Should I be buying a simple cable and software to use with my laptop?
I'm going out now to try to ground pin 8 and read codes from the dash, but I used to do this with my Probe (OBD1) a long time ago and I was never good at it!
Cheers! :)
Edited by MasterCookieman
