Remove Attached Pictures from a post?
Is it possible to remove one or more attachments from a post? Reason I ask is I was adding a few more bits to my Journal and noticed that with the new forum software you no longer get thumbnails but instead you get the full image (which makes sense as most people should have moved away from 56k modems by now!) and I noticed that where I'd messed up a few attachments I am now getting images related to posts either above or below whereas before you couldn't really tell!
Yes Dave, just go to the specific post, click edit and remove the offending article. Easier to have 2 windows open when doing this, the one you are editing and the other in its entirety so you can see what you are deleting. HTH
Thanks Groover - I found that if I used 'Manage Attachments' I could click the X on the icons at the bottom of the screen to completely delete the attachment. I'll start migrating the pics over to PhotoBucket.
Bloody good journal matey!!!!!
Alz.
Thanks mate - thought it would be good to share the adventure with the rest of the forum. All the piccies are appearing twice or in the wrong order at the moment due to the above but I'll start sorting that out.
Sheesh that took some sorting out! I've added in a load of new video clips too that I had knocking around on my hard drive so take a look.
Talking about your sig mate, you appear to have coke can size discs. lol Should that not be 330mm?
lol good spot mate - in my head I said 330 mill, and that came out as ml not mm! Will fix.
