She's alive! But still few questions remain ...
Yep - as stated above - after 5 months she's alive again!
1 - when cold iddles fine, when warm -jumps from 800 to 1100 rpm up and down?
2 - slow acceleration response (when acceleration pressed fast - around half second/second gap, when slowly - no gap) ...?
3 - fitted PTU model 2 (brand new) - no ignition, fitted back make 1 - good to go .. why?
Is there someone with Conzult in London?
Congrats on getting it sorted mate..
Some things to look at;
1 Check the tps and IAA and adjust if rec.
2. Throttle cable slack maybe and needs adjusting. Or throttlebodies need balancing.
3. Maybe a problem with the type2 loom adapter or a duff PTU.
Once again - cheers for help, will get back to work then... tomorrow..
