Me again.
So I have two questions:
RobHowl ·
Yep - as stated above - after 5 months she's alive again!
1 - when cold iddles fine, when warm -jumps from 800 to 1100 rpm up and down?
2 - slow acceleration response (when acceleration pressed fast - around half second/second gap, when slowly - no gap) ...?
3 - fitted PTU model 2 (brand new) - no ignition, fitted back make 1 - good to go .. why?
Is there someone with Conzult in London?
