Turbos
Hi does anyone ever fit the T28 turbos from a 200sx s14?
Surely it's not that hard they both use same exhaust flange T25 then use the s14 elbow which uses 3bolt to down pipe my just need a little fabrication to meet elbow to the 300 down pipe?
The reason I ask is a friend has 2 T28rs turbos and I can have them cheap
What do you guys think?
Paul
Cool will find our later exactly what turbos they are think there bb turbos gt28rs will check if so will get braided oil feeds ect
GT2560-R there a little high spec than 28gt-rs ( newer )
conceptsZ will sell you the complete fitting kit think i paid $180 dollers
that came with all parts inc gaskets ...
Ok just spoke to him there actually GR2871r .64ar turbos, will these be a tight fit or will there be enough room for them on Megan racing ss manifolds?
If they'll fit I'll have them as there at a bargain price
nice size tub ... but even with my ones fitted there is about 5>8mm between the tub and chassis rail on the drivers side so even that is very close ...
go to the garret site and look up the spec size sheet for both tubs and compair the AR out dir size
plus there is one other problem u gonna have
as both of those tubs are on a inline 6 there both identicaly setup
you will need one tub rotating/clocking for the Passanger side and a
new actuator braket making to suit
Normal tubs the act sits in 90* to the flange
the other side is more like 45* to the flange due to the Inlet housing being rotated
By them specs they should fit shouldn't they?
Also how do people fit big turbos like the z1 600r turbos ect? Do they cut out abit from the chassis rail n move it further in to allow a little extra room?
Edited by 111mattin111
According to ConceptsZ they have that turbo package for sale .... and no modification needed ...
will i can tell u that's a load of bolllox as i had to with my tubs
reshape the chassis rail for clearance ( driver side )
cut & reshape the heat shield ( Turbo housing and Outlet flange )
cut and reshape engine mount ( Actuator was in the way )
grind some alloy off the oil pump ( Actuator bar was sitting on it )
grind some fixing lugs of the turbo ( for Flange adapters )
http://www.conceptzperformance.com/Cart/description.php?II=3516&Car_Type=300&UID=2012051703194478.144.61.213
Edited by MarkDerby
472560-5015S Garrett GT2871R Ball bearing turbocharger:
- Oil & Water-cooled bearing system.
- Fits Nissan SR20DET engine, comes fitted with 0.64 A/R turbine housing
- Direct replacement upgrade turbocharger for 466541-1 & 466541-4 used on Nissan SR20DET engine
- Upgrade turbocharger for GT28RS (739548-1)
- Turbine stage outline interchangeable - Provides better boost response than the 743347-1 & 743347-2 turbochargers
- T25 turbine inlet flange
- Ideal for smaller displacement engines with packaging constraints
- Ideal for smaller displacement engines making up to 460 BHP
- Turbine housing option available
- Actuator not included
472560-5015S is a direct replacement for 472560-0015 Nissan 200SX turbos
should be fine .. depends on what t28 is fitted but will do from 300>350hp per turbo with out any problems
the only problem u will/may have is the actuators wrong size and fitments and u will need them Clocking for Left/Right
