throttle Bodys .. someone told me
ok i bumped in to some one at japfest
he started to talk to me about getting more power out the engine
by adjusting the throttle body's so they open all the way ( flap 90* ) to body
now i seen what he showed me what to do but Does it ?
as i thought it was strange seems i haven't seen it on here
any ideas / thoughts on this
It has been mentioned before Mark and its not true im afraid. If you look at the angle of the intake of the TB it does already fully open to allow the most air in at the best angle. If they opened up further, you are then hindering the air intake. Bigger throttle bodies are more likely to give a better air intake, but i dont personally see how much difference it would make.
well thats my thoughts on it too ... but he was very convincing on what he was saying ... and even show'd to what look like the flap/butter fly to only open about 70>80* Deg
he says to do away with the Spring adjuster stops and manually set it there in a different position
Not heard that before but you can fit bigger throttle bodies and a Q45 MAF (90mm)
Grinding the stops was the way to do it and as said the angle would be wrong with the butterfly at WOT, there is a thread on it somewhere, will try and dig it out.
Copied from Robos pages
We are currently creating content for this section. The jury is still out on this mod as to whether or not it really helps. Until this mod is tested on a dyno the results are unproven.
http://s95014253.onlinehome.us/mediac/400_0/media/DIR_14950/DIR_182763/TB~butterfly~flange.JPG
This is a schematic drawing, not to scale, looking down the barrel of either one of the two throttle bodies with the intake hose removed. Both pics represent wide open throttle (WOT). The two diagrams represent before and after the mod described below. The idea is to present a smaller surface area of the butterfly flange to the rush of incoming air at WOT, which presumably will allow for better flow. The red circle is the cross sectional area of the TB. The black line is the outer edge of the butterfly flange.
The blue line represents both the diameter of the TB and the "long axis" of the ellipse that is the butterfly flange at WOT. The short vertical grey line is the short axis of the ellipse, and is the only variable in our equations.
When the round butterfly flange is opened or tilted, the shape of its surface presented to the incoming atmospheric air changes from a circle to an an ellipse. At WOT, the "flattest" possible ellipse should be presented to the incoming air for maximum flow.
By bending the metal tab in the pic out of the way, the butterfly flanges open further, decreasing the length of the short axis of the ellipse.
http://s95014253.onlinehome.us/mediac/400_0/media/DIR_14950/DIR_182763/centerTBclosedbeforemod.JPG
Surface area (SA) of a circle, in this case, our TB's without the butterfly, = Pi ®squared
SA of the ellipse formed by the open butterfly flanges = Pi x (long axis x short axis)
At WOT, TB SA = (TB opening surface area) – (butterfly flange surface area).
If we designate x to be the TB SA after the mod, and y the TB SA before the mod, then x - y = z, with z being the additional SA gained for air flow in one throttle body after the mod. z/y X 100 = percent SA gained after the mod.
The difference is significant. This difference is even more striking if one realizes that flow does not have a linear relationship to the size of the pipe. Poiseuille's equation states that flow through a pipe is inversely related to the FOURTH power of the radius. Therefore, small decreases in the radius of the blocking butterfly flange should lead to proportionately much larger increases in flow. All measurements are for one throttle body only.
http://s95014253.onlinehome.us/mediac/400_0/media/DIR_14950/DIR_182763/drvrTBlnkgWOTbefore.JPG
http://s95014253.onlinehome.us/mediac/400_0/media/DIR_14950/DIR_182763/passTBlnkgWOTbefore.JPG
The Throttle Position Sensor (TPS) located on the side of the throttle bodies. I have heard of more than on person who only got his TPS to calibrate within spec after this mod. There is also a possibility that this mod increases the voltage from the TPS to the ECU at WOT, which leads to a performance gain.
Assumptions and potential errors for doing this mod include:
1) These are all theories that have not been tested or backed up in the lab or on a dyno. There is a rumor that Paul at Avalon Racing once showed a gain in horsepower with this mod.
2) Measurements of the butterfly flange were "eyeball" estimations, but the numbers were kept conservative in order to reduce any false positive benefit.
3) The throttle bodies are mounted at a slight downward angle to the intake plenum. This means that opening up the butterfly valve all the way as suggested above may not in fact be presenting the lowest possible surface area to the flow of incoming air.
4) Poiseuille’s equation was originally described for laminar liquid flow, then later applied to turbulent liquid flow. This example deals with turbulent gas flow which is somewhat of a stretch, but acceptable IMHO.
5) This still begs the question as to why the Nissan engineers would not design the butterfly flanges to fully open from the factory.
6) The effect on the TPS voltage also needs to be documented but is another possible source of a gain in performance from this mod.
Top
Ive heard and read about it to. But the general concensas was as groover said, if you look at the intake angles its already opening up to max. And forcing it to.open more will cause resistance.
or you could just get some of these :balloon:
http://www.twinturbo.net/net/viewmsg.aspx?forum=classified&msg_id=159917
It gives you an idea of the increase in air flow together with some pics of the work. The dyno graph is
incorrect wrt to the results between stock and 54mm (you can search for more info on this). A later run hasn't been published.
62mm TB's :thumbup1: http://www.twinturbo.net/nissan/300zx/forums/general/view/2477619/1st-CNCd-billet-62mm-TB-is-nearing-completion.html
http://www.twinturbo.net/nissan/300zx/forums/general/view/2478029/Stuck-the-GoPro-in-the-CNC-for-TB-boring.html
Edited by bigh
well yes and no ... its not what i asked about but its real nice but $400 + shipping + import +vat hhmmmm think i will leave that for now
