targa drain points
this must be one of the daftest things nissan did designing this car . allowing the rear drainage to discharge into the sills .
ive recently discovered the dreaded metal cancer around the rear drain points . while cutting away the corrosion i decided to reroute the drains to a safe place where they cannot corrode . firstly i renewed the whole piping from the targa right through and then made a new exit point . the original drain tubes at the sill are going to be removed and the gap closed .
heres some pics of the new set up .
an easy and cheap job that could save you plenty . only costs about £5 a corner
