300zx TT cannot get it to start correctly, Help before it bursts into flames!!!!
- Replies 28
- Views 1.6k
- Created
- Last Reply
johnlegs 14 posts
Medallion Man 5 posts
vodkashots 2 posts
MarkDerby 2 posts
- No registered users viewing this page.
I will try and explain this problem and everything I have tried to fix it.
1. The car will not start but turns over.
2. Occasionally between starting attempts the car makes a cough as if its going to start then continually turns over with nothing.
3. Fuel pressure, Compression, Spark, Injectors, Airflow meter, Ignition Amplifier all changed and fault remained.
These next two point may enlighten someone to recognize this problem.
4. I remove the intake pipes from the inter cooler to the throttle flaps and spray some easy start into either of the flaps then attempt to start it the car starts purring perfectly and runs with no problem obviously until the easy start burns off.
5. If I block both intakes off completely after spraying a little easy start into the plenum and I take the throttle position sensor off and turn it fully to simulate full throttle then start the car it will run at 1500 rpm perfectly and until I switch it off...?????
I hope someone can shed some light on this problem
Many Thanks in advance
