Third Break light
If I remove the central blanking part of the rear spoiler, will the wiring be there for me to connect a third break light?
can I just connect it and away I go?
If you have a UK then probably not. Some do but I suspect it's more likely that they have had a JDM tailgate put on at some time in the past.
Yep, it is a UK tt targa 1992. I am just in the process of drilling out the rusty screws that hold the blank in place.
If it is the case that I can not just plug the break light in, is it an easy wiring job?
or will there be nowhere to take the power and switching wire from?
I've always fancied a third break light, it will be a pi**er if it's not possible.
It can be done but you would have to take a feed from the rear lights back up and through the tailgate down to the brake light. Apart from feeding the wires through it's a very easy wiring job mate.
Cheers Steams,
Hopefully will have the blank out tonight and will know for sure, although I know you are right.
I am just clinging to a glimmer of hope as my wiring expertise is not great.
Should know for sure soon.
Cheers Steams,
You never know mate, you might have a jdm tailgate with the wiring ready to go, then happy days. lol
Well, just managed to SHOOT myself in the foot!!
Managed to drill the heads off the screws, only to realise the screw needs to be removed before the bl**dy unit will come out!!!
Arrrggghhh!!
