NA steering pump
What do I need for replacing TT steering pump to NA?
I got na pump
na pod
all brackets
but what about belt?
belt it is different , so does NA steering pump belt will fit on normal TT pulley ?
The NA belt is a three rib belt and pulley and the TT one is a four rib belt so the TT one wont fit and the TT pulley isn,t interchangable onto the NA pump so you,ll need an NA belt or remove one rib from the TT belt with a sharp knife , you do need the Pump AND Bracket as it,s different , but on a good note the TT power steering pipe does fit onto the NA pump :thumbup1: HTH
yeah do above but all so when u put it on the crank side it needs to be on the outer 3 ribs
Thats what I be told before. But what i done today even better.
All day i was trying to find na belt but no one had for sale. So what i done is...
I took off pulley from tt pump rurn other way and fited to na pump and thats work Perfect. So now my na pump running tt belt.
Nice one , but i,m sure no matter how tried i couldn,t get mine to fit , hmm interesting that . :thumbup1:
If you use tt pulley just turn around front face put on na pump back face. And its perfect!
