auto turbos
I JUST Bought two turbos off an automatic for my manual 300zx and read they are not the same size as mine just wondering did i waste my money
  • Replies 27
  • Views 850
not all bad .. yes they are different a little but u will have a faster spooling turbos but u may just notice the power may be a little flatter at top end
They will still bolt on. iirc the spool up quicker than manual ones to make up for the slow all auto box :lol:
i just think its just cuz your welsh ..
got a friend from down there ( llantrisant )and he talks really sloooooooooooooooooooooooow lol
Edited by MarkDerby
Are they both different and what's the exact difference, it says a/r .48 m24 on them and what should they say on them
FFS!!!!! how many times IM NOT FOOKIN WELSH!!!!!!!!! :rant:
And is there anything i can do like change parts with my old turbos or should i try get me money back and try get manual turbos?
if the seller sold them as manual tubs and they are auto's then your with in your rights to get a refund
and how did u find out they are auto's as from the look from both types there the same
Sorry thought u was seems your in North wales lol ... first i heard of it anyways :)
u fell out with me now :sad:
still shag sheep though, don't ya ;)
They were on a automatic one that he was breaking they could off been changed is there any numbers on them to tell for sure if they manual or automatic ones
Fell out?? no not at all you have to be mates to fallout! :lol::lol:
Try :lol:
Edited by Car.Mad
The only way to really tell is to take them apart and see, there isn't any markings on the outside iirc. tbh, You'll be fine with auto tubs on a manual. There isn't really any difference in performance in the real world.
i doubt it m8 .. most drivers would of fitted/recon auto tubs as the Manual ones would be to lazy for the auto box
Ah they for my track car so i dont really want to be going back in power. I may try send them on, is there any turbos on off a skyline, silvia that would be an improvement on standard turbo that would bolt on and fit the 4 bolt downpipes really should of asked before i spent my money
t25 from skyline s13/14 use the same tubs .. but the problem u will have is they use one sided tub setup
the z32 needs left/right ... the passenger turbo needs to be clocked by 60deg and will need a different actuator bracket fitted
as it sits at a 45* angle to the wast gate flange
if u look at the tubs u have there u will see what im talking about
It isnt a power difference, its a spool up difference, on the Auto they spool up quicker but loose the top end.
you get quicker acceleration with the auto turbo s, but are about 10mph slower at full whack.
So il only feel it a the very top end eg. 5th gear or will it drop off thru all the gears, will i still be pulling to redlind in lower gears
through gears up to red line as the tubs will spool sooner to give u more lower end RPM grunt but will run out of steam high up the rpm range ,,,,
Edited by MarkDerby
Ah get u now, its really just one turbo that on the way out the passenger side would it be ok to use 1 manual nd 1 auto turbo?
