August 7, 200223 yr when setting off and giving my car some stick,it seems sluggish at first then given a couple of seconds it seems to just kick off and really fly. is this normal for automatics or does is sound like i have a prob?
August 7, 200223 yr I hope the engine is already hot when you do this? Ie. Oil pressure below the middle when moving, engine temp moving up between 1/4 and 1/2.
August 7, 200223 yr Mine's an auto..but never boot it when first thing. Let the car warm up. Have heard nightmares where people boot their car's from cold. So I'd say just drive normal for a few minutes then play...
August 7, 200223 yr Try cleaning the temperature sensor connectors. I had a similar issue with my 5 speed. I often left the AC on for better pull from lights, it would have a little bit of a stall between 800 and 1000 RPM. Cleaning the temp sensor connector fixed it. Acutally that and a trip to see JeffTT which made a world of difference.
August 7, 200223 yr Do you mean a sort of pause as thought the thing is winding itself up?? I have this but have put it down to turbo lag and torque convertor - not too sure how torque convertors work tho' - anybody?? I quite like it, it's like from no torque to massive torque in an instant.
