Clutch issue!!
Decided to bleed the clutch to see if it would take up any of my excessive pedal travel,
Bled it from both points and it reduced the travel by half,
Does this mean I can adjust the rest of the travel out from under the dash?
One thing that I have noticed since bleeding, is that I get a squealing noise through the full length of the pedal travel, a bit like a rusty hinge.
Is there any way I can grease/oil the offending parts?
You can adjust the travel of the clutch under the dash, but you dont want to go mad and have it nearly hitting the floor lol. Yes the dreaded squeak, i still got that on mine, its the spring being too dry, give it a bit of spray grease/lube, will help till the next time.
