clutch Q
will a tt clutch fit in an na gearbox without modification...everything bar the flywheel
thanks
i suppose so, as you can use the na box, you would have to alter the bellhousing take a chunk out and space the starter to mesh up with the fly wheel.
i thought that.justim having trouble finding a decent n/a clutch that isnt from the states
whats wrong with your current clutch if you can find a new one why not get it relined
its slipping real bad but i need to fit a new engine so may aswell do it while its out
Pretty sure Jeff does uprated NA clutches. Maybe give Zedworld a ring.
Below are some pics of a couple of clutch options we supply or supply and fit, manufactured for us in the UK to our own specifications so no import duty and no silly delivery times, all brand new.
The first picture is a 25% upgrade item mainly used to replace a standard unit with a little extra clamping force and material strength.
The second picture is a paddle clutch and is available in 5 or 6 puck depending upon spec required, the clutch cover features upgrade fingers and steel inserts, the plate has progressive double shock springs which makes this paddle clutch feel almost stock unlike others which end up been like an on/off switch the friction material is stable to very high temps and load.
Matching lightened flywheels available from UK stock too.
Jeff TT
