TT VS. N/A steering rack
I done conversion on my car it was na but now is TT so I fit in TT steering rack and now I know that its got same plug (electronic valves which controls something SO...
My steering wheels is heavy. what I can do about that? I allready installed some spacer in rack to get more lock so I dont want to change all rack How can I just fix o remove that electronic valve ?
The lower the voltage to the solenoid the heavier the steering. Connect it back up to the power steering controller
There is no plugs on the car there i can connect
I was on the understanding the TT and NA racks had a different lock to lock ratio
There were two different racks used on the zed but I don't know if it was a TT N/A difference or just one superseded the other?
So how i can do just a normal rack how to remove that valve sensor?
The valve is to control the amount of power steering. More at lower speed, less at higher speed. If you do manage to bypass it and have a normal low speed power steering, you'll fall off the road at high speed. Connect it back to the controller. Find the wires.
but I have N/A body shell I think i doesnt have that plug , N/A steering rack is different from TT . no ?
All Z's have the controlled power steering. In fact just about any modern car you name has some form of power steering control otherwise they are VERY twitchy at high speed e.g. first edition front wheel drive Mitsubish Sigma (don't know what they call them over there)
Thanks for this but could you tell my where is that plug? I fit tt model got harness going fron hicas selenoid to steering rack plug.
