Dual Air Filter Induction Kit?
Need Help!
Got carried away on eBay and bought myself the above without doing any research! It has dual cones.
http://www.ebay.co.uk/itm/150779666245?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Can anyone tell me if this will bolt straight on or will it need new mass airflow meters etc? I'm also thinking of getting the car remapped - will this need doing before bolting on? Based in the midlands, does anyone know of anwhere that does this?
Help GREATLY appreciated!
It should bolt straight on bud. It still uses the single maf. Technically speaking, it's still a single intake but with 2 filters. Doesn't look like it will give very efficient air flow though?
Thanks for the response :)
How so?
It just replaces the air filter yeah?? Sorry for sounding dumb....Its all new to me!
I recently fitted a single cone apexi filter on mine, you have to remove the previous air box (getting it off the rivetts is a pain in the arse), I just screwed mine straight on the MAF sensor and it really does the job gets more air, turbo's spool up quicker, right result!
Thanks! I'll ATTEMPT the fitting at the weekend...so I'll probably be on here Sunday night scratching my head!! :)
Fitting will be fairly straightforward. I'm sure there is an induction kit fitting guide somewhere, but it will become straightforward as u get stuck in.
Sorry, when I said that air flow doesn't look great, I was comparing it to a single induction kit. I don't see how this would be any improvement over a single. However, it should be a big improvement over a standard air box
