Remapping
How can do remap for my zed. I know steve in fctunning can do but he charge £450 plus £60 each hour on dyno. So thats comes rufly about £550. So that quit a lot. Does anyone knows other places?
  • Replies 26
  • Views 1.2k
If you set the psi at 14 for example then the boost controler will keep the turbo wastegate closed untill it reaches 14 psi as your boost level reaches this the controller will begin to open the wastegate to stop overboost the gain controls the rate at which the wastegate is opened. If you set the gain high it will and hold the wastegate closed untill the last second then snap it open causing the boost to come on but if the wastegate doesn't snap open it will cause overboost, if I were you I'd set the gain so that the boost comes up and sits .3 psi below max boost then creeps the rest of the way, just keep yuor eye on it when you set it up
