Reverse manifold
The engine is nearly ready to go in the S14 but for the turbo to clear the steering rack the perfect solution is to fit a passenger side exhaust manifold on the drivers side, so 2 questions
1) Any performance/running issue in this?
2) How easy is it to drill/tap 6 new threads for the bolts as the are opposit to the orifinal ones?
Before anyboddy gets confused this is a TT engine into the S14 body.
If I understand you then do this, might work...........each TT or NA head has 4 threaded holes around each exhaust port on the head with only 2 studs screwed in diagonally. All you need to do is remove the 2 studs per port to the opposit diagonal on all 3 ex ports and then your manifold will fit.
you should be ok to drill and tap them mate here is a close picture off my head and you can see the holes clearly.
I have 3 sets of heads, 2 TT and 1 N/a set and all have 4 holes..............strange.
Hope you come right.
Got the engine out and guess what, omly 2 holes each side?? How come others have 4??
