looking for instructions to fit an air fuel meter
where can i find the destructions for fitting this ?its the 2-1/16 autometer gauge
thanks jay
think i need to chat to andy,is there a way to connect the wires to the ecu,instead of direct to the 02's
Jay, i got a Lumention LED Monitor for air fuel ratio, also AFR as well, both are wired into ECU harness, not that hard, if yer down billing give me a shout and i'll gladly show you, just fit yer gauge and bits and leave wires down by ECU ready to sort out after, then 10mins and yer done.
cheers smithy,i'll be there all weekend,look out for my black zed!
smithy any help on the wire to the ecu would be appreciated m8,thanks jay
Okay here goes Jay, i have 5 wires off mine, 1 is white and connected to nothing ( for some other feature)brown is the earth, now the other 3, removing ECU and pulling it straight back towards you and lying on it's back so all pin connectors are visable, on your left nearest you and the top line, 2nd wire in is white, i connected my red, directly below on next line again is a white wire, i connected orange, lastly my black wire went to the 1st black wire on the top line of pins, hope this helps buddy.
smithy
