seperating rear lights
ive had a look but cant seem to find a thread showing pics of how to seperate rear lenses .
has anybody got a link please
cheers
andy
Heat them up, make sure there's no screws in and prose them apart carefully... Job done
Membership No 0780
INSURANCE GOOFA
Hi Andy.....
pm me your emails address and I'll send you a copy of my guide....
it's a composite of some of the other guides out there with other bits in.... should make it very clear...
I'll also include a list of tips and bits to be careful with...
(like the "take your time" advise below)... :)
Edited by Medallion Man
only thing i will add is take your time, if you try to rush them they will crack............i found the rear lights trickier to do than the centre panel.
thanks guys , im going to be doing something different with these . never seen it done on another zed before . they should look ultra modern but not out of place . i will post pics on the progress
One thing I found very useful was, once I had gently warmed them in the oven at 50 deg'C for 15 Min's, before I prised them apart I ran a 15 thou feeler gauge all the way round as deep as I could get to help separate the lens from the housing. worked a treat. lookout for the locking tabs, they are very delicate. also, there is a small self tapping screw in the back, this needs to be removed first. It may take a couple of attempts, returning back to the oven for a few minutes and working gradually around the whole lens bit by bit.
right ive got them seperated and the first fit of the new lighting set up fitted and tested . i,ll get some pics on when the new set up is perfected
