upset / peed off / feal sick
after working on my car for the past 5 months doing stuff
i get it on the rd today with tax only for one of the
Brand new Turbos to give up ,,
i'm upset peed off and feal sick
this car is starting to fook me off now i want to ........
  • Replies 40
  • Views 1.5k
No worries mate, good to be preparred. As in pressure though i meant at the point at the back of the block where the oil feeds come from just prior to fitting the new turbo's.
Good luck anyways fella.
smithy
Turbo Dynamics
but if the turbo has failed due to manufacture problem this has no baring on the Comp
just to make that clear dont want to be seen bad mouthing
will report soon but its going to be another few weeks yet anyways
smithy
no way of seeing that as gauge isnt plumbed in there ...
but i can not see oil pressure being a problem as it wasnt with the last turbos
and its using the correct restricters for tubs as supplied
thay say it comes in 3's
Mondeo Turbo over a week ago
Nissan turbo Yesterday
Now some one just crashed in to my van ..
Cut me up on a Island and Damaged his car bad and
paint work and Bent my steering/arms ..
my luck it all against me lol
Edited by MarkDerby
wow things just aint going right are they.
Dont quit like so many before you have its always worth it in the end
Id do a compression test first,you ran 14 psi with an old engine and a set of basically t28 tubs ? That sounds like a recipie for disaster mate.Bet youve blown a piston in fact id almost say its 99.9% gone bang.
Jim are you saying that if you replace the tubs with uprated ones you should check engine condition first?
Should be common sense really! if your upping the power/Boost then you need to make sure your engine can cope with it. If its got worn seals HG or piston rings the increase in power is just gonna make the weak points in the engine fail.
it is common sense really to check the engine condition ... however my engine was done Last year before i put the engine in anyways ..
oh bad luck mate :( well you've had your three pieces of bad luck all together so now I hope it can only get better. Hope you get it all sorted mate, especially the Z!
Crikey mate, bad times indeed, happens to the best of us, things will get better pal, they always do, chin up...
So i guess you should carry out a compression test to Asatain condition of the engine first.
What would the ideal compression readings be....anydody know?
Am I right in saying you sorted a UK warranty with the tubs? So you won't have to ship back to the States?
171 psi is standard. Minimum of 128 and no more than 14 psi between cylinders
Thanks mate:thumbup1:
