July 29, 200224 yr I recently had the engine out and it stood on end in the workshop for a couple of weeks. Now that its back in, its got one noisey hydraulic lifter. Looking in the manual it says you should always keep the tappets the right way up when you remove them otherwise air gets in and they go noisey. Do you think this could have happened to mine while the engine was stood on end? And how the hell can I purge the air out of it without having to strip it back to the cams???? Cheers in advance ZHead.
July 29, 200224 yr Its a common problem - but the noise usually goes once the engine is run I take it you put fresh oil back in? Have you run the engine for a while to give the oil chance to circulate back in to the lifters?
Cheers in advance
ZHead.
