July 24, 200224 yr Had autobox probs for a while & have just done done the diagnostic & it came up with "Revolution sensor is shorted or disconnected". How do I fix this, what parts do I need?? Cheers Jay ------------------
July 24, 200224 yr Oh dear this could spell trouble, if your problems are intermittent loss of drive or/and noise from the box it is most likely that a rebuild is needed, the revolution sensor is slightly magnetic and any metal floating about will stick to it and give an ecu error code Depends really on what your symptoms are with the box got some more info? Jeff TT
July 24, 200224 yr Just seems really slow, feels like clutch packs are slipping. I put my foot down & it takes a couple of secs for the power to hit the wheels - Thought it was turbo lag to begin with, can only describe it as "gearbox lag". Any ideas?? Cheers for the quick reply Jay ------------------
July 25, 200224 yr Originally posted by Jeff TT: Jay, Jap or UK spec? Jeff TT '92 UK Spec Jay ------------------
July 26, 200224 yr buger me.. there must be something in the air, mine has started displaying these symptoms the last week or so. When first started in the morning/ or after the car has beeen stood all day, ie at work, then it seems reluctant to start moving when drive/or reverse is selected. when you start to drive it appears to be clutch slip, dont tell me this is gonna be a rebuild im skint enough as it is i havent done a diag yet, might try one tomorrow. i have noticed that the problem goes away after a couple of minutes though.
July 28, 200224 yr ive just done the auto diag and all is fine. my fluid is not burnt, or smell burned, although i havent checked the level when hot, will look at that tomorrow. jay, you gettin anywhere with yours?
July 28, 200224 yr No progress matey, next job is to check the condition of the autobox filter, see iff there's any bits of clutch gears etc. When the car is stationary & I switch to D or R the car jerks slightly - anyone have anymore ideas?? Jay ------------------
July 29, 200224 yr jay, ive found the problem with mine. i reversed off the drive to see a big puddle of gearbox oil this morning. bollocks!!!! so the reason i wasnt gettin any drive was that there was no flaming oil in the box. BUT... i checked the oil when cold and there appeared to be loads in there, i diddnt however check it when hot (was going to do that today), oh well it has been trailered off on a flatback to the garage to be fixed. bummer.
Jay
