Manual gearbox oil change.
How many litre i need to add to gearbox?
sorry LT for going abit off
but could someone put up pis n a write up of how to change the G/B oil..sorry if theyrs allready a thread but its just popd into my head that this might not have been done on mine..thanks
Theres two hex plugs, one on the bottom of the box and one on the drivers side of box, roughly half way up(ish).undo with an allen key socket (forget the size), drain oil and refill.you cant miss the plugs....worth doing the diff oil at the same time :)
cheers dill
am i right i thinkin that it should be mt 75-90 ..also is redline stuff as good as its made out to be
MT 75-90 good stuff, not cheap mind, time you've got 4 litres. Think Opie Oils do it from memory
they aren't hex/allens, they are 1/2 inch squares, so any 1/2 inch ratchet/breaker bar will do, but be sure to undo the filler before you drain it, as if you drain it then cannot undo the filler for whatever reason, your fooked...
would that be coz it unpresurized or somthing..
i just search youtube but its all z31 vids
nothing on these cars are cheap or easy..lol..but thats the price we pay for have great cars
Mines got hex plugs :)
think maybe yours has been done before and the plugs have been changed coz the originals were f00ked
No it aint its square m8...:turned:
Bloody hell, I thought they were hex when it was on the ramp today!......my mistake then, I stand corrected!
Hows you this evening Mr Dent? :)
Just chilled out watching the news .:dots:
Im off up the wooden hills now.....been a busy day!, see you soon matey :)
