rear poly bushes
Does anyone know where i can get them as cheap as possible??
on ebay they want £350/£400 and im not paying that as the bushes are really good anyway. just thought i would swap then whilst the subframe is off
I think these are everything for the NA
Rear Differential mount bush X2
Rear Wishbone-lower, front/rear bush X4
Rear Radius arm-upper, inner/outer bush - std X4
Rear Control arm-upper, inner/outer bush - stdX4
Rear Toe/track arm, outer bush - excl HICASX2
Rear Toe/track arm, inner bush - excl HICASX2
I have two arms already poly bushed. Its the 2 smallest arms, anyone know what they are called??
I polybushed the entire rear of my Slicky with the Driftworks ones. Got it all done at the same time as fitting the DW hicas eliminator. Massive improvement imo.
do you know if the raidius arm is the camber one.
Ive worked it out and it will only be £200. once done every componant will be brand new :dance:
Every bush you need ive listed up top. Just want to confirm the radius arm is the camber one. on ebay it says it can adjust -1.5 to +1.5 so im guessing so. i dont need this one as i have camber arms so will save £75 there :)
No as above, I think when they say radius arm they mean the tension rods. See here as example - pics of tension rods with 'radius rod' listed - http://www.300zx.com.au/pricelists/pricelist_suspension.htm If you have adjustable tension rods already then you won't be needing them either.
For camber arms I think you/we still need the bush that goes at the chasis side of the arm. I've got my booked in next monday to go up on the 4 poster lift to have a look for myself and see what I need to order for when the adjustable arms and coilies go on.
There for the front suspention. we call then tension rods.
I know what your saying about the camber arm/radius arm now for the hub but im not paying £80 for 2 bushes :shock:
This one. http://www.ebay.co.uk/itm/Nissan-300ZX-Z32-89-00-Rear-Radius-arm-upper-inner-outer-bush-CAMBER-ADJ-/270814539929?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f0dcdf099
Yes there's tension rods in the rear as well - what that ad is saying (I think) is that by using those bushes on rear tension rods would effectively alter your camber if you have non-adjustable arms.
there the Rear Toe/track (or hicas)arms that your mixing up with tension rods. they have nothing to do with the cambers
Think I'll get a quote from Mr F for the rubber ones for lower control arm instead of poly, can't really justify £80 - sandy was offering a whole subframe for £80 last week :lol:
you mean the outer upper radius arm :lol::lol:
the rest of the kit will be fine. i think :wacko:
Aye upper control/radius arm :lol: .........looked at far too many bushes tonight and trying to do too many things at the one time!!!
I've got front and rear upper and lower arms, toe rods, tein front tension rods, hicas lockout kit, tein coilies with electonic control unit, front rack, full 120k service kit.....now I need to spent another few hundred on perifieries!
Sack it bit the bullet. got the whole lot including the camber/radius arms £335 :cry:
This na diff better be worth it.
I dont. proberly easyer just to buy the proper kit as the price will most proberly be the same.
