0.55kg equal to ?psi
Kg/cm2 value = equivalent in psi
0.50 kg/cm2 = 7.11psi
0.55 kg/cm2 = 7.82psi
0.60 kg/cm2 = 8.53psi
0.65 kg/cm2 = 9.25psi
0.70 kg/cm2 = 9.96psi
0.75 kg/cm2 = 10.67psi
0.80 kg/cm2 = 11.38psi
0.85 kg/cm2 = 12.09psi
0.90 kg/cm2 = 12.80psi
0.95 kg/cm2 = 13.51psi
1.00 kg/cm2 = 14.22psi
1.05 kg/cm2 = 14.93psi
1.10 kg/cm2 = 15.65psi
1.15 kg/cm2 = 16.36psi
1.20 kg/cm2 = 17.07psi
1.25 kg/cm2 = 17.78psi
1.30 kg/cm2 = 18.49psi
1.35 kg/cm2 = 19.20psi
1.40 kg/cm2 = 19.91psi
1.45 kg/cm2 = 20.62psi
1.50 kg/cm2 = 21.33psi
1.55 kg/cm2 = 22.05psi
1.60 kg/cm2 = 22.76psi
1.65 kg/cm2 = 23.47psi
1.70 kg/cm2 = 24.18psi
1.75 kg/cm2 = 24.89psi
1.80 kg/cm2 = 25.60psi
1.85 kg/cm2 = 26.31psi
1.90 kg/cm2 = 27.02psi
1.95 kg/cm2 = 27.74psi
2.00 kg/cm2 = 28.45psi
Off the supra forum :lol::lol:
cheers mark
On other forum you said it was 55 cmHg.
cmHG is not the same as kg/cm^2
55 cmHG = 10.6 psi
0.55 kg/cm^2 = 7.8 psi
Edited by Yowser
yes i'm trying to get to grips with the dual blitz timer. when in motion it reads cmhg. then on tickover there is a peak power reading when you scroll through. which is 0.55kg
