Starter motor
Hi
Can anyone give me some some advice on where to get a starter motor from local to fareham hampshire,also how easy is it to change as i have only got a driveway to do it on ie: i have read it needs tobe done from underneath jacked up etc, first start it is making an overthrow noise like you get if you hit ignition when engine is running then its ok then you leave car does it again happening more frequently now so need to get it done ASAP preferably in morning sunday if not raining so its ready for work.
Any help would be appreciated.
simon
SIMONM5@SKY.COM
Jeff TT will be able to send you one asap and are £65 delivered iirc, Really easy job to do, take off the connector and the earth then its just 2 bolts. its on the drivers side of the gear box :)
