tt manual propshaft with Na
does anyone know. Can I connect first have from tt lwb manual propshaft with second half of Na lwb manual.
the lenght both is the same 606mm so does in fits together ?
No, the first half of the TT and N/A are the same 606mm second half differ
manual TT prop length (spider to spider)
1st half... 606mm
2nd half... 508mm
manual NA prop length (spider to spider)
1st half... 606mm
2nd half... 539mm
1st half... 606mm
2nd half... 508mm
1st half... 606mm
2nd half... 539mm
Well but I have Na manual propshaft allready but I ripped off bearing that I was putting on trailer so No I just need first front half. so does it connects right to Na rear half ?
Ok in that case it will, i thought it was for a N/A rear diff conversion lol
to what Jeff Posted on my thread about this yes ... but u have to take the joint of the TT front half and put on the NA joint on to the TT front drive shaft ...
Personally i dont think its worth it and i just opted to put the hole complete NA drive shaft on
take a look
http://www.300zx.co.uk/forums/showthread.php?159376-NA-to-TT-Diff-conversion
Yeah mate i done nq conversion. I had tt subrame and now i got na one.
So all you saying and seen in the pictures that is not ganna fit together is that right?
yep correct ...
u have two options
Fit the complete NA - Manual Prop shaft ( lighter than TT ) or
Use the front half of the TT Prop and take of the Center joint of and Put the NA one on
but in doing this u could get a balancing problem as your taking it apart and fitting other parts
yep correct ...
u have two options
well What about if I will change just bearing because I got Na complete propshaft but bearing and that all rubber is been ripped off. So is there any chances fitting other bearing?
yeah u can do that bearings are the same on all ... just make sure you mark the shaft and the joint so u put it back in the right place
Its looks is a hard to change them, could you recomend me how to do?
yeah its not that easy i use my impact ranch to do stuff like that but
would say u need a good long cracker bar to put some force in to it sure that would work
