Wipers Aircon and clock DEAD!!
Morning all! As most of you know my Z is my daily drive. Got a problem that occured a few days ago, everything was fine then when I went to start the car one morning I noticed I had no display on my aircon or clock.. Also the Front wipers won't work!!! The following day it was still dead but on a drive went over a bump and everything Sprung back into life and started working again! Great I thought!!!
Then on leaving work the other day nothing at all again and now it still dead... Im assuming A relay has died on the back of the fusebox next to the drivers accelaerator pedal.. Anyone know what colour relay controls those accesories so I can swap it and bring everything back to life??? Thanks for anyone who can help me!!!
  • Replies 27
  • Views 4.4k
SO, just checked the Zed again and clock is still out - earthed fine but not working. I may try to do the soldering to fix it or source another. The thing that still hasn't been rectified is that the LH side of the dash - the speedo and temp gauge do not light up. Without taking the dash apart to check the bulb, is there another fuse that does just this side of the dash separate to the accessories one I just replaced?
If you have any dash or pod lighting at all then it will be bulb related as they are all on the same fuse.
