ECU reset?
After finally getting her on the road, I have been driving about with the timing 10 degrees out (I set it up using the induction loop on the PTU, and after reading Jeff's write up, I set it up using his way), and has made a wonderful difference, however, seeing as the battery had been off for ages, it has self learnt with the timing out, is it worth me resetting the ECU so it can now learn with the timing set up correctly, or will it just re learn?
Cheers, Tudor.
It will re-learn but may take a little while, so a forced reset would do no harm at all.
