Clutch bleeding
Hi,
Any tips on bleeding the clutch been pumping the pedal but nothing yet been at it a while, second time box has been out first clutch got replaced by a mechanic now I have done it has the clutch fork was cracked.
any advice would be great.
cheers mark
Cheers mate, done the slave will have a look in the engine bay, mine was a auto but now manual so might not have the bleed point under the bonnet will have a look later:-)
Mark
When i converted mine, i got rid of the long bleed pipe and bought a master to slave pipe from the zcentre for £20, then bled the slave up top, before i fed it down to the gearbox, so much easier. I did find my slave cylinder was seized, so had to work the piston in and out for a while till it freed up. It then bled in no time at all.
That's what I did too, makes bleeding it much easier.
Thanks groover found that bleed nipple under the bonnet and it bled in a crack :-)
cheers mark
On 300ZX TT IF YOU JACK THE FRONT OF THE CAR AS HIGH AS YOU CAN IT MAKES THE AIR IN THE SYSTEM BLEED OUT BETTER FROM THE CLUTCH BLEED NIPPLE NEAR THE RH. TOWER AT THE FRONT OF THE CAR.
why are you shouting mate?
I think alot of the bleeding problems are caused by not enough vacum on the up stroke of pedal because of worn master cylinder seals .When i replaced the seal in my master bleed first time .Its a simple fit its a replacement cartridge with new piston seal just a circlip and slides into the body of the master.Mine bleed first time after changing this .
