Have been having a few problems getting my boost to set correctly.
So does anyone here have one in your z that you can show a diagram of how you have it plumbed in please.
I have it plumbed in as folloes on mine
Pressure sensor dirict into balance bar
Solonoid has two sides, COM & NO.
COM is linked via a t-peice from both Wastgate actuators
NO is then linked via t-peice direct to both dump valves.
But still even with the avcr set to off(so shouldnt boost above .85bar it will boost to death when it shouldnt go above the .85bar.
Have i plumbed anything incorrectly?
you dont plumb it to the Bov's ... Bovs will open when there is only negative Vac ( Off throttle )
it should go to the main inner hard Boost pipes ( ones to carbs )
but how u have T'd both Turbos and Both outlets is correct
(In) COM is Boost IN ( hard Pipes )
(Out) NO is to Wast gate
Edited by MarkDerby
