N/A Diff Conversion does it need N/A Speed Sensor ?
going to do a Conversion soon and have all the items needed
does it need the N/A Speed sensor
as thinking about it the sensor is on the gearbox and it wouldnt know what
RPM/rotation the wheels will be outputing
Mark
  • Replies 36
  • Views 2.9k
well i will be on a TT g/box then on my slickie so will be in the same boat
You wont fit an N/A speedo sensor in the TT box, you will have to calibrate your clock. Or it may be possible to fit the cogs of the N/A sensor to the TT one, Jeff may be the best person to ask.
the difference in the senders is the size of the cog on the end. changing the cog wont help the big cog wont fit in the small hole and the small cog wont touch the sides in the big hole.
when i put a TT gearbox in my NA the speedo was a considerable amount out. I talked with Jef at teh time, they were puzzling over the same thing and were suggesting a relocation bracket so the NA cog would sit over to one side and touch the next cog.
i wasnt sure tis would work so i bought a variable speedo adjuster,
easy to fit: fitted it where my mph /kmph converter went, drive along with a sat nav, look up in manual provided actual speed and speedo speed and choose the correct setting
[sIGPIC][/sIGPIC]
From the follwoing aticle:
http://upload.z1motorsports.com/Z1%20Z32%20NA%20to%20TT%20Conversion.pdf
The speed sensor gear in the transmission is different, different size for NA and TT because of
the different ratios in the diff. So if you are using a NA diff you need a NA speed sensor gear.
The speed sensor is different auto and 5 sp also.
strange they say that as when i tried it the na speed sensor didnt work in the TT box
[sIGPIC][/sIGPIC]
The speedo does have two adjuster pots on it, I calibrated my speedo by adjusting them, you have to melt two holes in the casing and put a small screwdriver in there but it means you can adjust while driving along :-)
could just move the needle and set it with GPS .. ?
Recommend you don't do that unless you set it to absolute zero first, not where it rests on the pin as it falls further then that. It's so easy to damage these clock by removing the needles!
moving the needle wont help as it is a percentage wrong not a fixed amount wrong
what hellrazer suggests is good for the earlier cars but doesnt work on the later cars from 94/95 onwards as the speedo design changed
[sIGPIC][/sIGPIC]
got another Q for the Guys thats done the conversion
Just taken me 3 hrs to get the hole lot off ..
the 2 bolts i had a problem with was the ones that hold the Hicas on
other than that all was fine ..
i dropped the diff with subframe togeather
all my new subframe/diff/arms/hubs have been painted up and ready to fit
the Drive shafts ... i Have both half's of the N/A drive shaft
Will the Rear part of the drive shaft Mate up to the TT front center drive shaft ?
and is the NA diff a limited slip one ?
and all so How do you fill it with oil ?
yeah i have the Rear Half of the n/a center drive shaft .. just looks like the bolts / hole spacing are smaller
thanks for the link
you dont need the front half of the diff but I didnt get round to removing it :)
u mean font half of the drive shaft ... no diff right ?
doh what a thick bstard I'm tired ok :lol: i meant front half of prop. you definately need the front half of the diff or the oil will pour out and there will be nowhere for the prop to mount lol.
How did you do this mate. where did you do the holes etc got any pics??
holes will be in made on the side/top ajsent to the dail .. u will be driving with the clocks on the dash but not bolted down ...
Link dosnt work :(
Had this problem since the new forum. just asks to sign in :(
ahh crap another problem just for me. Says thanks for logging in then goes back to the sign in page :(
Can you copy the pics and txt for me mark?
