rear wheel stud removal
hi I've done a bit of searching here of how to remove a broken rear wheel stud mine has the handbrake built into the middle of the hub so what do i remove to knock the broken stud out i don't see any holes at the back of the hub for removal but if i remove the brake caliper does that reveal were the hole is
cheers trev
ive just done mine, its not a problem, remove the caliper, remove the disc , you may need to use the provided jacking holes to assist removal ( make sure handbrake is off ) then using a good brass or copper drift bar and heavy hammer drive the studs free, then remove one of the brake shoes , from this point its obvious that you can remove the extracted stud. you can easily then refit the new stud(s) make sure you coat the new splines in good copper slip to help them slide through and ensure you use a spacer and old wheel nut to pull the new stud into position.
if you are stuck let me know
