-15 10j
EDITED:
K ignore the title just thought id ask for help from the experts again for their wisdom about offsets and so on.
i want rota GTR-d front 9.5j offset ET25
Rear 10.0j offset ET35
Whaddya think?
Edited by Hollings
change of subject ;)
There gona stick out loads it will need more than an arch flare i Think over fenders are needed .what size and offset for the front wheels.
fronts are 9j +29, so thats cool, its just the rears are monsters, wondering how much camber id need with some arch flare? without looking silly!
cheers for info taff!
beyond camber and arch flair, you'll need a wide arch kit
for comparison, they'll stick out 48mm more than mine, my arches are rolled, pulled & flared.
well i just sold 8.5j x 19 fronts and 9.5j x 19 rear and they fitted ok. And you dont want them, not like i have just ordered a set or anything! :lol: If your after a set then i found revoution 247 good to deal with
should be fine, a 285 tire will need arch rolling on the rear from what I've seen.
excellent so 18's in the first post with those widths and offsets will be good? I was planning to stretch the tyres anyway so won't be going that big, fingers crossed!!
Cheers for the info guys!
yes, sorry, meant to quote to make it clearer
  • 1 month later...
Just as a matter of interest what rim width and offsets are you running on the rear mate
and generally what offset (with slight tyre stretch) on a 10" wide rim do you think you'll get away with by just rolling the arches?
Hi dont know if you have ordered these or not yet but mine are 9.5J all round et30 on the front and I think et35 (can't remeber) on the rear. I have 225/40/18 front and 245/40/18 rear. My rear arch's have been rolled and i dont get any rubbing at all. my fronts are rota gtr's mind not the gtr-d
couple of pics
So to answer my own question, at a guess I would think that rolling, pulling and flaring the arches should enable the outer edge of the rim to sit an extra 15mm-20mm further out without having to go down the wide arch kit route?
I will have a look tomorrow for you and see how much room there is.
cheers mate, I'm just racking my brain working through some measurements and offsets at the moment
