July 13, 200224 yr i pray that you can help me. i am not able to find out why this cylinder is not firing. i have tested all wires going to coils and injectors. i i get juice on 2 wires and other is ground at all cylinders except last one rear drivers side. it only has voltage on middle wire and not to red strip wire. thus i am getting no change in engine when i remove coil connector with engine running. also getting raw gas in exhaust causing it to burn there and i know this can damage rings and cat and many other things i have also removed connector to ptu and find same wire to coil is dead at this point. no voltage. is it a broken wire or bad ptu or can i test at ecu? i do diagnotic on ecu and get code 55 - no malfunction. is it compensating i am lost pls. try to help me. J.R. ATLANTA GA.
July 13, 200224 yr im no expert but it sounds like a broken wire to me? you are gonna need advice from jeff tt or andy or nico.they are the guys on hear who know there stuff.put a post up for them to get there attention.jay
July 15, 200224 yr You need to try changing the PTU for a known good one. Sounds like there is a connection broken internally on the PTU. Have you checked the other connector to the PTU just to check??? HTH CheerZ, Andy
July 15, 200224 yr i should of known better !!ive just done my ptu mate ...andy is right !!! have a look http://www.aus300zxclub.com/tech/moveptu/movingptu.htm
no voltage.
is it compensating
i am lost
J.R. ATLANTA GA.
