protoj ·
Have managed to reduce my total kerb weight by about 7kg from Jan 1st. By being on weight-watchers :wink:
Not trying to plug weight watchers but feeling pretty happy with my stage 1 weight reduction. Must be the equivalent of adding a couple of bhp.
