120k service kits
I will be listing a genuine one for sale in the next day or so. No longer required is the only reason. Here is a pic for now if you are interested.
Result :thumbup:
Can you list what you've got or just delete from the list below anything that's not included so I can price them up seperately mate? Email me on youngross@hotmail.co.uk with price.
Timing Belt
Timing Belt Tensioner
Water Pump
Water Pump Gasket
Thermostat
Coolant Bypass Hoses x2
Variable Timing Control Springs x2
Variable Timing Control O-rings x2
Camshaft Seals x4
Crankshaft Seal x1
Crankshaft Sprocket Spacers(F+R)
Drive Belts(3 Included)
Crankshaft Sprocket
Idler Pulleys, Timing Belt x2
Idler Pulley Studs/Washers/Nuts x2
I'll go through it all tomorrow for you. It'll be in the evening. Nearly all of what you've listed is there iirc. Apart from the Drive Belts, this is because they differ for TT, NA, Import etc I think. So you can order the specific ones you require.
Good stuff, perfect timing.
No pun intended eh :detective: lol
Timing Belt 13028-45P86
Tensioner 13070-45V04
Water Pump B1010-22P27
Thermostat 21200-42L01
CB Hoses 14055-F6511 x2
VCTS 13072-45V20 x2
Oil Camshaft Seal 01001-00191 x2
Oil Crank Seal 13510-10Y10 x5
Crank Pul Plate 13022-45V00
Crankshaft Plate 13023-45V00
Gear Crank 13021-16V10
Idler Pulley 13077-F6510
Idler Pulley 13077-F6200
Stud 13075-F6501
Stud 13075-F6500
These are all the parts, all genuine Nissan in original packaging.
I will give you first refusal before I put them on general sale.
You're next in line then Mark. Only fair to let misty have first refusal. I'll await an answer then PM you.
